Just completed my first re-piping task in the cloakroom (sink and toilet). I was a bit nervous of my soldered joints as I'd never done it before, but none of them caused any problem. The compression joints were more prone to dribbles until tightened again. Is it just a case of getting used to tightening to the correct pressure, or is it worth adding a bit of PTFE tape or putty to the joints?
I bought some flexible hoses to connect up the taps and what a nightmare on such a small sink! I tried a basin wrench, wrong size. I tried an adjustable wrench and couldn't get it on. I tried no end of spanners and still couldn't get a grip. A similar post in the tools section recommends a box spanner. Is 27mm/32mm the right size to attach one end of a flexible hose to a tap?
