leaky laguna
14 Dec 2005
Sussex
Hi, since we have had all the lovely rain, my 96 18rt laguna is getting wet inside. the front and rear carpets are sopping wet. i have tried to see where the water is coming in, been using a hosepipe,bucket etc, but cant see any where its coming in. Is there a drain anywhere on these cars that may be blocked? it has a factory sunroof, but doesnt appear to be letting in water through that.
cheers :D
Hi, seem to remember these having problem with the door seals leaking with wind and rain, water runs down the rubber seal and into the carpet.
when you next test, really try to force the water in through the door aperatures and then once excess water has run off, open the doors and see how wet the seals are.
What mileage has it done? Take a look at the seals to see how 'flat' they look.
cheers for that. its done 114k.and the seals do look flatish. i will see how much a new set are.
