Hi all,
I had a bathroom installed a few years ago which included a towel rail/radiator.
When you turn the valve to increase/decrease the heat a small amount of water will spill out quickly and then it will drip consistently. In order to stop it dripping there are a few 'sweet spots' on the thread where the dripping reduces to a few small drips an hour which after some time usually seals itself up (presumably due to the very hard water in our area). If I then touch the valve (like when I knocked it cleaning recently) the dripping starts again.
When I turn the valve it turns unevenly on the thread (like a car with a loose wheel), but it doesn't feel like it is cross threaded.
Any ideas how I go about fixing this? Is it possible to replace the valve? I cant see any make/model for the radiator so I am not sure where to begin. WIl that part even screw off from the radiator?
I am familiar with removing and working on normal CH radiators but never worked on a towel radiator before. I presume that they are plumbed into the hot water feed as opposed to the CH?
Thanks for your help
