Referring to the dig above, I've got a window that during the gales this week let water in between 5 & 8.
I have no idea where to seal it. I certainly don't want to seal it between the sill (9) and the window because I'm sure water can get into the frame and if I seal the outside it won't be able to drain out. (is that assumption true?)
I can't be sure but I have a feeling the whole window is sitting on the exterior sill. In which case sealing between 5 & 8 would be a good place to put sealant because any water getting into the frame will make its way out.
As I say I'm pretty certain water's getting into the frame, in which case should I cut my losses and replace the whole window?
