Leaky Zanussi. HELP!
20 Oct 2004
Zanussi Aquacycle 1050. FLS 1183W. Not emptying properly and leaving stagnant smell. Leaked from underneath - a lot of water. Caused the fuse box to trip.
Could it be one of the two "bellows" type pipes leaking onto the pump motor or the drum seal split?
If you had a straight leak then the water would be leaving the machine either through the drain hose or the leak.
Leaks from underneath the machine won't in themselves cause the fuse to go as the electrics are up at the top .... apart from the pump.
It could be that the pump is blocked or there's something wrong in that area. You'll have to have a look. It should be fairly obvious where the water's coming out.
