Hi there
Well, I need to construct a lean to over a path between my house and the boundary fence. I will of course be checking planning requirements and with the neighbour first.
My idea is to use polycarbonate sheeting for the roof, but I'm not sure what the best way forward is for the walls, cladding or drainage. I was thinking of using WBP with batons which I can stick insulation between and I'd like to clad it in white overlap boards, but not timber, I'd like to use those boards they use for cladding houses which don't need painting regularly. I'm not even sure where to get them or what they're called - any advice on this?
Drainage - to use the space efficiently we need to go right up to the fence. The polycarbonate roof will be sloping down to it from our house. Are there any drainage solutions out there which would help? Or do I really need to worry about it - can I just let water drip off and soak into the gravel by the fence?
Many thanks for any advice!
