Relative has the following lean-to roof...
- Concrete marley etermit tiles on batons, felt, T&G close-boarded,
rafters. 22-degrees.
- Close-boards stop at the double-brick wall, tiles are then bedded on
felt, on mortar, with mortar edging.
Over the double-brick wall at a north-facing corner for about the
bottom 15" the mortar is falling out and the felt is disintegrating.
Interesting population of woodlice. The result is a damp stained
plaster-skim over browning for about 6-inch below.
Q - How can I effect a reliable roof repair?
Is it a case of wedge & lift tiles, put *impermeable* roofing membrane over the wall on mortar, overlapping it onto the existing felt, bedding the tiles onto the membrane with mortar?
Q - What is the correct & best membrane to use?
Felt rolls are too heavy for me to handle and I'd rather pick up a proper membrane for when the roof is properly redone (more weatherproof interlocking tiles re 22-degree pitch and a lot of insulation).
