Lean to shed
30 Mar 2015
We have a detached property with a side passage. I am planning to building a small wooden lean to shed which will be 2.6 metres tall against the side of the house. We will still have a side passage.
My neighbours kitchen looks on to this and currently they see the fence and the side wall of the house.
Are there any issues with this?
If I read this correctly, there will be a gap between the shed and the boundary?
The lower part of your lean to should be under 2.5m
There is a 85cm walkway between the shed and the boundary. I think the lowest part will be just under 2.5m. It's a very shallow roof.
Technically, the highest part of your shed is 100mm too high, but I can't see your neighbours getting their tape measure out over such a slight 'miscalculation'
You should also be a metre from the boundary unless shed is constructed from mostly non- combustible materials.
What is the size and intended use of this shed?
The shed is to store tools and made purely from timber with a rubber roof. It is around 50cm wide and and 6 metres long. It runs alongside the house and the side passage.
Thanks for your help with this.
I'm afraid so. The rules for side extensions seem to apply, it's not a shed.
It depends on other factors including where it is attached to the house, and the number of storeys.
IIRC, an example anomaly is that you may not be permitted to build a two-storey extension, but you could build a single storey with a really high roof.
Thanks @^woody^. I don't have any concerns from a planning or neighbour complaint point of view then.
