Lean to with corrugated PVC sheet
6 Feb 2013
I am planning on building a lean to on the back of my garage 2300mm x 2400mm with a slope of 10 degrees.
I'd like some help with what timber I need to buy for the outer construction and then for the purlins.
It has to be strong enough to support the corrugated PVC sheet and a heavy snow fall please.
I'd also like some help with the number of and the spacings for the purlins please.
The sheet comes with the following specs, Height: 0.08cm Width: 66cm Length: 2.4m Weight: 1.88kg.
Thanks in advance for your help.
Joe
I would use 4x2" at approx 18" centres for rafters and a bundle of 2x1" batons spaced evenly to fix the sheets to.
