Leaving the nest …..
19 Apr 2022
Pulling my hair out. Having had a complete house rewire, with mixed feelings about the quality, I’m at loggerheads with the contractor. A nest learning thermostat has been installed, and it’s nothing but trouble. The heating wouldn’t stay on, with the 3 port valve rapidly clicking. The plumber diagnosed a defective 3 port valve, because the system was drained down for a week and then refilled after a couple of downstairs radiators were repositioned to accommodate wiring changes and access.
A new 3 port was fitted. Same problem persisted. Plumber says it was necessary work to eliminate confusion, and narrow the issue down to the rewiring. The electrician says all is good with his work. The Nest has been set to manual, and still plays up. Narrowed it down myself, without either contractor on site.
When the nest water schedule is asking for hot water it’s fine. When the tank thermostat is satisfied it turns off water AND heating even if the nest room thermostat is asking for heat to the heating system only. The only way I can get the boiler to then ignite is to increase the tank thermostat above the temp we want, to a level higher than being requested on the nest room thermostat, which means our hot water has been scalding.
The Electrician says this is normal. Can anyone out there advise? Is this normal in a nest install? If it is I will be leaving the nest for sure …..
Of course it's not normal. Your electrician is wrong. He's wired it wrong and from the sound of it either doesn't understand what he's done wrong, or doesn't care.
It would be - HW only on a 3 port valve doesn't require the valve to do anything, it's at HW only by default.
The rest is because it's been wired incorrectly.
