LED Bulbs Flickering
6 Sep 2009
Cleveland
Just installed some 4W LED lamps into spotlight fitting - when turned off they are flickering! I've checked polarity and it seems fine.
Only other thing i can think of is it has a timeguard timer switch with photocell operating it - would this have something to do with it?
If so how can i over come this or can LEDs simply not be used with timer photocell switches?
It is probably voltages picked up by induction from an adjacent circuit.
The usual cause is that there is no earth (or no connected earth) in the lighting wiring.
I think you'll find that those timer switches are not to be used with 'non normal' bulbs. If you don't have the instructions, you can search on line for them, Timeguard are pretty good at having stuff on the internet
Agree with sparkybird, if you only have 2 wires going to the switch it is relying on the neutral through the load to supply the required voltage to the switch for it's electronics to operate.
A normal lamp has a few 10s of ohms, LEDs will be a lot higher.
It is possible to buy a small device for fluorescent lights which connects across the load to allow the correct voltages at the switch, it might work with LEDs but you'll need to confirm with timeguard: http://www.tlc-direct.co.uk/Products/SMFLA01.html
Hi there I've got exactly the same problem as you and wondered how you got on??
I've tried calling timeguards tec support but they don't answer calls.
Any info would be great.
Thanks,
Devs :)
i have several led bulbs off differing sort in various locations and none give any probs with glowing they all go out but i dont have any on timers so the problem is probably wrong sort off timer
Hi Bernard, do you know what product would work 240v 3w GU10 LEDs? Ideally the easier to fit the better. Sorry to ask but I'm unsure and am keen to get the order in asap so I can get my hall lights working correctly again.
Many Thanks!
I use the following
Capacitor 0.047uF micro Farads 250 volts AC
Resistor 100 ohms
Which come pre-packaged as a contact suppressor from RS Components
RS Stock No. 206-7847
Manufacturer Evox-Rifa
Manufacturers Part No. PMR209MB5470M100
I have fitted them in ceiling roses between neutral and switched live
There are other sources of the contact suppressors
Many thanks for the help Bernard, do you think they will work okay with gu10 led via a spotlight fitting? Typically RS are out of stock at the moment so I will get some ordered as soon as they return to stock.
Sorry for the questions but this is all new to me.
Cheers again,
Steve.
