- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Large room had single lamp in centre which at 12.5 watt LED did not really cut it, so been looking for a light fitting to take multiple bulbs to increase output, found a fitting with 8 E14 bulbs so fitted that, leaving just buying the largest E14 (SES) bulb I could find. Wife picked up 2 at 5.5W 470 lumen at £2.20 plus vat. My existing stock were 2W in the main.
So into HomeBargains and picked up 8 x 6W bulbs around £2.29 each, rated 470 lumen then noticed the 5W bulb at around £1.29 also rated at 470 lumen. So swapped the bulbs in the basket. Both bulbs were same make.
So why three bulbs all 470 lumen with 3 different wattage ratings? And higher the wattage or the less energy efficient the more they cost. With such a low wattage can't really measure with plug in energy meter, and £10.32 for 3760 lumen is good valve.
But why do same make of bulb vary so much in price from same shop.
