Is there a standard derating factor for LED lighting.
Im a bit confused how many LED lights dimmers can handle.
For example
Lutron suggest that a 10 Watt led should be treated like a 100w incandescent
So a 600w dimmer can only safely manage 6, 10-20 watt lamps ( The jump from 10 to 20 w seems quite a big jump)
THE 10 % rule
That sounds like a very low amount of lamps.
Varilight say
Options of 120W or 300W (Up to 10 or 30 lamps)
No wattage of lamps given!
Zano say
0-150W or 5-250W
Not limited to 10 lamps
(no indication of lamp wattage or number of lamps
When I asked they said to use 'Regulation guidance of 1.8'
Which I presume to be the derating for inductive loads such as fluorescent lights.
Many thanks
For example
THE 10 % rule
Varilight say
Zano say
0-150W or 5-250W
Many thanks
