i have 12 MR16 50W dowlights in my kitchen and I'm looking to replace them with LED lamps instead.
My budget is £25 a lamp. Each lamp has its own transformer at present so I guess I need to replace the fitting as well as the bulbs.
I see that there is a 'new' technology out there which is Chip on Board just to add to the general confusion. I also understand that you're better off replacing the fitting with a LED specific fitting than trying to retrofit some of higher power replacement bulbs into the existing fittings due to thermal management.
So with this in mind, can anyone recommend me a downlight that is as close as possible to halogen performance?
I'm happy enough with the concept of downlights, and don't intend to replaster the ceiling so no need for suggestions to replace downlights with another form of lighting.
