I've read these forums quite a bit as a guest and got the help I needed. I'm hoping someone will be able to help me with my own question now.
On the exterior of my house I have 3 PIR Security lights and have recently added a 10w LED light attached to a time lag switch that will illuminate the dog pen for our guide dogs.
The LED light, when attached to the supply works fine. I have wired it correctly to the time lag switch and when the switch is activated the light remains on for the appropriate length of time. However, the LED light flashes when the switch isn't activated - the neon indicator on the switch also flashes in time with the LED light.
Video of the light flashing:
http://youtu.be/sptQ1HCzfAA
Instructions for the time lag switch:
http://www.cpelectronics.co.uk/phpincs/deliver_pdf.php?type=extras&id=51
LED Floodlight Website:
http://www.gwsled.com/productshow.aspx?id=81
The time lag switch instructions recommend using 1uf of power factor correction for each item being switched. I have emailed the company and they have recommended using 4uf of power correction factor capacitor. The switch company recommended this http://uk.rs-online.com/web/p/polypropylene-film-capacitors/4515354/ for installation in the light fitting across the switched live and neutral connections.
I have a couple of problems though:
1) Space in the back of the LED is very limited, would it be ok to install the capacitor between the switch live and neutral in the junction box (pictured)?
2) If I can install it in the junction box, does anyone know a) which size should I buy and b) where can I get one with leads rather than push connectors?
3) Would I have this problem with a 120w Halogen floodlight?
I've looked at a few posts about this issue with LEDs, one of which recommended 0.1uf capacitor and 100 ohmn resistor which lead me to purchase http://www.maplin.co.uk/contact-suppressor-498 - which didnt solve the problem and I realise why - LoL.
If I'm honest, I'm beginning to wish I had just bought a £5 halogen 120w floodlight. The LED one cost me £10 and I like the colour and crispness of the light, but buying these additional capacitors is just adding to the cost.
Thanks for any help you guys can offer.
A few pics to clarify things...
And for anyone wondering why I want the setup I have... The front and back garden are covered by a PIR, the side section of the house has a PIR pointing towards the front garden so that it activates when we approach the side door. Our guide dogs use a pen for their "business" and this pen is in the section that isn't covered by the PIR lighting - plus, when they go for their business we are often stood still so the PIR wouldnt see us anyway. I didn't want a normal switch either because nobody seems to be able to turn anything off in this house and the light would probably be on constantly. Hence, a time lag switch that keeps the light on for a programmable amount of time and a nice LED light.
