LED Lamp/ Dimmer Compatibility
11 Jan 2004
Hello
I am trying to match the Megaman 148139 LED lamp with the MK K1523 LED dimmer, which MK states is leading edge.
Megaman do not mention this MK switch on their compatibility charts so before I contact them tomorrow does anyone know off-hand if these two will work together?
Cheers!
I've had miserable luck with MK's LED dimmers. I think the K1523 is based on the same unit as the K4511 which seems to be somewhat incompatible with all of the Philips and Megaman lamps I've used - the Philips lamps buzzed quite loudly and the Megaman lamps were ok to about 50% brightness. Below that and they'd flicker at all kinds of brightnesses.
Had no trouble with Varilight dimmers.
Cheers.
Thanks for helping me decide: what I will do is buy the cheapest MK dimmer and an AU DSP 400x module to put in it.
That will set me back £20, 36.50 less than an K1523 dimmer!
