LED plinth lights, started flashing
28 Oct 2014
Manchester
Morning
This time lst year I installed a set of Wickes LED plinth lights into my kitchen plinths.
They worked fine for about 6 months.
Now when I put them on they stay on for about 5 minutes then start flashing so I have to switch them off.
They are plugged into the transformer they came with, which is plugged into a socket behind the plinths which is turned on at the wall on a spur.
Has anybody got any ideas what this could be down to.
They are relatively new, but I don't have the receipt and don't really want to rip them all out.
Chris
So you've put up with this fault for about 6 months?
:rolleyes: You knew when you bought them that you would need the receipt if the went wrong after a year or two. If they obviously came from Wickes, e.g. has their name on, speak nicely to them - they might be helpful.
It probably is the power supply, so you're going to have to remove the plinth to get to it.
It won't be a transformer though. It will be some form of switch mode power supply. Probably 12v DC (need to check the label). Easily replaceable if so.
I haven't put up with it, I've just not used them over Summer, been too busy to sort unfortunaely.
I kept the receipt for a while, but can't find it now.
I'll check everythings plugged in OK under the plinth, but I don't understand how they can work fine for 5 minutes then just start flashing.
Thanks for your idea though
Really?
The transformer is just under the kitchen cupboards behind the plinth.
Surely that's where they're supposed to go.
Thanks though
It may be overheating due to a defective component, but it could be anything. Unless you're going to take it apart and start bench-testing - I wouldn't worry about it.
I have seen exactly the same with PC power supplies and digi-box power supplies they all worked A1 to start with then some safety feature started to turn them off. Could be heat or just the components in the auto shut down drifted but cure is the same new power supply.
In the main be it a AC or DC output they are switch mode and even if you could get into them fault finding is a nightmare so it is replacement. There are loads of name tags from electronic transformer to driver but what is important is voltage if AC or DC and current rating. Read the old one and post details and likely some one will advise on replacement or simple go to Wickes.
On the other hand, it could be that one of the LEDs has developed a short, so the driver is shutting down on overcurrent then resetting.
Talk to Wickes, they're usually helpful.
