Not sure if this is possible
I'm fitting one 16 watt LED PIR flood on a rear wall.
There are 3 existing conventional lights on the same wall switched from inside the house. The cable for these runs in trunking past where the new PIR light will be fixed.
Is it somehow possible to tap into this circuit to power the PIR light without having to have the 3 existing lights constantly on?
Trying to avoid running a separate cable to the new light.
Thanks.
Thanks.
