Hello,
Another question on me on the subject of wiring in LED Tape..
I have ~6m of LED tape connected to a 12v DC power supply.
Between the PSU and the start of the tape is a run of around 3m.
Because it was a handy size, I've temporarily hooked up the tape with 2 core 0.75mm cable and all works fine. Total draw of the tape I believe to be around 72w.
On subsequent googling, I see many people suggest 1.5mm cable - but the reasoning I can find for this appears to be around voltage drop. The 0.75mm cable is much larger than that on the tape connecting strips (looks like bell wire) and seems to be working fine - so can I just stick with this, or should I really use a thicker cable?
