Got these from Maplin.
http://www.maplin.co.uk/white-decorative-led-strip-lighting-383747
Kitchen units are not installed yet. Would like to fit these under wall units.
The transformer is in the 3 pin plug supplied. Instructions describe it as a low voltage (12V) adaptor.
My intention would be to route the wires horizontally in 16mm plastic oval conduit behind the kitchen base cabinets, plugged into a spare socket behind the washing machine, then running the wires in the same size conduit vertically to each wall unit, the conduit being in chased out channels. These would then be filled in & tiled over.
Would this be an acceptable method?
Thanks.
Thanks.
