I've got a problem that I've not experienced before.
On an external garage door, we've got a Legge mortice lock. I do not know how many levers.
The other week, the main key got stuck in the lock and I had to leave it in there whilst I worked out why I couldn't remove it. The key still turned, and locked/unlocked the door - it just couldn't be removed from the lock itself.
When I got down to looking at it properly, I could see that part of the key had become twisted, such that it couldn't quite be twizzled or teased or positioned in such a way that it could be removed. After a lot of teasing - it simply got the pliers on it, and pulled it out with a fair amount of brute force (with the handle and lock surround removed).
I think, that this is has buggered the lock - my schoolboy error was not to ensure that the bloody lock was UNLOCKED before I gave it some welly - d'oh!
Still, I am where I am. Upon removing the key and attempting to bend the small part of the key that had become bent back into straight alignment so that I could use it again - it had obviously become very brittle and simply snapped off - pic of the busted key below. Upon attempting to use the busted key now - it will turn, but it won't unlock or relock the lock - it turns through it's full run - I can feel some resistance as it turns like it's moving / hitting the levers, but it doesn't unlock it.... I had initially figured that the broken off part of the key was the reason!?!
I've managed to find the original spare key, and just tried to unlock the key with this. The spare key starts to turn, but gets stuck about a third of the way around the rotation and goes no further. I've attempted to "persuade" it with some additional force/pliers, but as you can see from the pics below - all it's managed to do is twist the remaining good key out of shape - I'm reluctant to apply anymore force to it, as I'm confident that this key will also perish.
Consequently, I'm stuck wondering if the lock is buggered (broken key turns but doesn't open, good key doesn't turn at all) - and will require a locksmith to open it?
I've given it the beginning of a look-see to see if the door could be jimmied open with a crowbar, but the door is extremely tight within the frame and the blade of the crowbar won't even slip into the gap between door and frame to begin to move it!
I want to save the door - am more than happy to buy a new lock and fit it - just need to get the fecking door open in the first place to be able to do this....
I've just thought about doing something with the hinges? It's a stable type - two-half door, with four hinges in total, two on each half. There is a small amount of the hinge visible from the outside of the door, where it looks like the pin of the hinge can be knocked out / removed and then the door forced open / off it's hinges with some force from the inside to at least get it open and acces to the lock to be able to remove / replace it? That's my best thought on it at the moment anyway....
Would appreciate any thoughts on how best to take the next step to resolve this!
View media item 74499 View media item 74500 View media item 74501 View media item 74502 View media item 74503 View media item 74504
