Thanks, does it not affect the cold side ?No just take the temp in the cylinder up to 60 degrees C and it will be fine
Hi, yes a small under sink one.Do you have an unvented hot water cylinder , post a pic if you are not sure
No you have an instantaneous water heater, not a cylinder, no need to worry just switch it on and run a sink full of water offHi, yes a small under sink one.
