Having a few issues with this cooker. What should have been a simple task has turned into a nightmare.
I took the door off the main over to replace the door roller catch and the only way to do so was to remove the top hinge.
However, trying to put the hinge back is where my problems started as the screws actually screw into a plate behind the fascia. The plate had moved backwards such that it was impossible to get the screws to make contact. Ok I thought, if I can get the top hinge back in then I'll take off the bottom one and try that.
Well that wasn't the best idea either as that plate behind the fascia for the bottom hinge dropped completely out of sight!
Anyone got any advice?
Don
Don
