My hot water vent pipe rises 200mm above the HW in pipe going into the 3 port valve.
Is this long enough?
I have recently installed a new Grundfos 15-60 pump (for 8 rads) however I think it is sucking in air on start up due to pump inertia and I suspect it is coming down the manual bleed valve on the vent pipe.
Can anyone tell me how long a vent pipe should be to prevent air intake on such a pump. The manual bleed valve is a total of 600mm in height above the pump.
My pump works great as long as I bleed it after start up. I am thinking of extending the length of the pipe as well as adding an automatic bleed valve?
I would really appreciate any input as I am a novice!
