hi
im changing two 22mm water pipes over to an opposite wall. once I've joined the pipes with fittings and flux how long can I leave it before I solder and if where im soldering one joint the heat from the pipe starts to melt the flux on another joint will it still be ok to carry on and solder the next one. im asking this as I've never soldered more than two fittings on a run of pipe whereas this will have perhaps five and I was hoping to fit it all first and then just go ahead and solder them all.[/b]
