We have a Leonard 722 thermostatic shower which runs from the Worcester combi boiler. I understand that Leonard were taken over by Mira in the late 70's? and that this shower then became the Mira 722. So obviously, if that's the case, mine is a good few years old. We've used it for about 13 years and it's performed well, and I really like it to be honest, but has a couple of issues, in that it can be difficult to get warm and stay warm. It can take some 'messing' with the flow control to get it just right and when done so, the temperature will often stay ok, but will sometimes go cold. Also, the temperature control does nothing. For example, you can turn it to the hottest setting and adjust the flow to get it just right. But if you turn the temperature control all the way to cold, the temperature will stay the same. And vice-versa, if it's cold, turning the temp up does nothing. The only way we can control the temp is by adjusting the flow, if you turn the flow up higher it instantly goes cold, and down again to get some warmth. I'm wondering if the cartridge has gone? Or if a service kit will help? Or even if those (which are available for the Mira 722) will work with the Leonard 722. It'd be a shame to change the shower, if I can get this one working perfectly again. Everything else with the water/boiler etc. is fine. Any thoughts appreciated please, thanks.
