Hi Experts. Though, in past months, I have flushed our Fernox magnetic filter with no particular cause for alarm (I'm always a bit nervous of anything to do with central heating, boilers and so on), today was a bit different. The only different circumstance today from earlier occasions, was that today, I was aware that the radiators were hot, whereas previously, I think it was a time of day when they would not have been heated up (because of the timing setup).
Anyway, today, the radiators were being heated at the time I intended to flush the filter. First, I turned off the boiler, totally. Then I closed the two red taps, so as to isolate the filter. The next thing was to open the little metal screw (a kind of pressure-release screw) to let out the water that had been put under pressure inside the filter. On past occasions when this was done, there was a kind of arc of spurting water, which lasted for perhaps five seconds or so before the arc collapsed. When it did this, I knew it was safe to unscrew the large plastic cap of the filter.
However, today, the water just kept on spurting out. After waiting (for too long, it seemed), I thought it would never stop, so, thinking that there was no other option, I unscrewed the plastic cap anyway, and took out the filter.
After flushing the filter, I replaced it and then screwed the plastic cap back on. The water started jetting out again, so quickly, I opened the two red taps. Then, after a couple of seconds (during which, the water continued to spurt), I closed the little metal screw.
After that, I turned on the boiler and injected some water into the system, until the display seemed OK.
Everything seemed OK when I left the boiler. However, the continually-jetting water referred to above has made me quite anxious. I should hate to do something harmful to the system, just for the sake of not enquiring.
So, my question is: Today, why did the water continue to jet out and not cease, as before? Another question is: will everything now be as it ought to be?
My thanks to anyone that can comment usefully on the above concern and that, hopefully, can answer my questions.
A.W.
A.W.
