Does anyone know if there are any regulations which cover the permissible level difference between adjoining rooms? We are just doing some feasibility to extend to create a family bathroom. The extension will need to be around 0.4-0.5 lower than the existing floor level. This would require going through the door and then taking two steps down into the bathroom. Is this permitted and if so are there any "landing" needs immediately inside the door?
I have looked on building regs around doors and their proximity to the "first step" but these seem only to relate to landings at tops of stairs. If that is the only requirement (which appears to be a min of 400mm deep landing area) then I can work with that. My concern is if you cannot have steps (down) immediately inside a door.
I hope this makes sense and if anyone knows the answer according to the regs that would be great.
