Level thresholds advice
13 Oct 2020
Hi All
A quick bit of advice needed to replace an old knackered standard patio door. It needs to be accessible to patio outside for a wheelchair user...would you go standard cill with rubber/aluminium ramps or level threshold with proper drainage (rather than just 'evaporation') channels for the British weather? Will only be able to afford to install this once and don't want to install something not up to the job of being properly weathered? If we do go level threshold...is it a case of 'don't scrimp on the cost' to guarantee the quality of the seals and drainage? Thanks in advance for any advice or wisdom you fancy imparting :)!
