Hi Chaps,
I'm currently looking at doing up my kitchen, and I'd like a little advice about leveling up a sloped concrete floor.
The concrete floor in question is in a single story extention that contains our kitchen, and adjoins flat wooden floorboards where the wall has been knocked through into the dining room. I can see what looks like a sheet type dpm in the brickwork outside, so assume there is a dpm in place under the concrete, but that is a guess.
The concrete area is about 2m square with a drop of about 3.5cm over the 2 meters away from the original structure. Essentially is's a steady run, from being level where it meets the wooden floor down to the 3.5mm at the wall.
The first thing I was thinking was; is it possible that the slope was intentional for any reason? I'm guessing it's just sloppy work, as I can't think why anyone would want a run on an internal floor.
Then I was wondering how I'm best to go about leveling it?
Previously it had a laminate flooring over the top, which had given way and broken up over the sloped area, where upon ripping it up I discovered it's just had extra bits of the green paper mulch underlay ripped up and chocked inplace to try and level it.
What I'm intending to do is put lino over the kitchen area, and then have carpet in the dining room area, with a strip inbetween.
Can I level this with the self leveling compounds from wickes etc, or would the part where my concrete & wooden floors meet be too shallow to use such products?
Also how hard a task is it to get these type of products level? I don't want to end up with something so uneven I can feel it under my feet!
