It's the old problem. Bitumen (not DPC, just adhesive) residue left from asbestos-vinyl floor tile removal. Bitumen is dry, but stable.
Need to level it.
I've put some experimental blobs of cement based leveller down in a couple of spots to test adhesion, and they seem to be stuck well. But I've read levelling compounds don't stick.
Now, is this only really an issue if you glue/adhere to the leveller (tiles, glue down wood...etc)? and put vertical tensile forces into it? I can't imagine it will do anything if you float a floor over it as there are no vertical tensile loads, and only fractional loads. Even if the levelling compound delaminates from the bitumen completely, it will still act as a shaped packer.
What exactly is the failure response of levelling compound over bitumen compounds?
Cheers,
Fubar.
Need to level it.
Cheers,
Fubar.
