Levelling a wooden floor
24 Dec 2005
Newcastle upon Tyne
I intend to put my fridge-freezer in an alcove in the kitchen. However, the floor runs from side to side and as a result the fridge rocks when you open the door etc. This means that i need to level the floor before tiling... the height difference is about 10mm over 1m so using more tile adhesive to level can't be the best option.
It is only a small area and i'd appreciate any ideas...
Chris
yes :) do it thick enough to trowel and then it will level itself when left.
or lay batten etc. down to contain the mixture
