Levelling compound query
27 May 2005
I have a couple of questions re: self levelling compound. Basically, I have a flagstone floor that needs levelling as it is in quite bad condition, also they are bloomin cold to walk on in the morning so I would like to lay some carpet on them and I don't really want to pull the whole lot up & replace with new ones or concrete because of time, mess & expense. 2 carpetters have said that it is currently too uneven to lay carpet - hence my interest in self levelling compounds.
So that's the background, I've read quite a lot about the compounds already so my concerns are quite specific:
What happens at the edge of the floor, lets say if there is a doorway or a step down into another room? What is to stop the compound flowing out of these open areas into another room? Do I need to use some wood to maybe box in these areas? Will the compound then be weak (too weak?) at these edges?
The other thing is the small gaps between the flagstones (one of which goes down to the basement), will the compound seep away through these? Or is it too thick to do this (or am I for asking?!)? Should I point up the joints and any large or distinct holes with mortar before I lay the compound?
Hope you can help,
Thanks for your time,
Matt
