Levelling existing concrete shed base? Gravel?
30 Jan 2014
Essex
Hi all, I didn’t get any response in the garden section so trying my luck here!
I'm replacing the 4x6 shed at my elderly parents house. It's literally just for mower/garden tools.
There is an existing concrete base but it's not very even, so when I've put the shed floor down there's some bounce in it in different areas.
What's the easiest way to level it off? Three sides are surrounded by gravel boards/brick so I was thinking of a thin layer of small gravel!
It doesn't need to be the perfect fix, just the easiest to be honest!
Read more: https://www.diynot.com/diy/threads/how-to-level-concrete-shed-base-gravel.572680/#ixzz6xn93Mw6Z
Get a pack of glazing shims or wedge packers from somewhere like screwfix, they are bits of plastic about 100mm long x 28mm wife and come in various thicknesses from 1mm to 6mm
Then pack up the floor joists until they no longer bounce. If you want it really solid get a few tubes of silicone and fill up some of the gaps bet joist and concrete.
I’ve got some in the garage. Never even thought of that! Only thing is the floor is already attached to the joists. Glue them to the joists so they don’t slip?
