Levelling extension floor
31 Jan 2011
Cheshire
Looking for some advice to level a concrete floor in extension. House is 1958 bungalow with mid-70's extension.
Extension is 18' wide where it meets with the wood floor of the main building and extends 8' out.
The floor is concrete and approx 10-12mm lower where it meets the wood floor, and approx 38-40mm lower at the exterior wall.
There is a channel approx 4"x 3" around the edges to accommodate heating and mains.
So 5.4m x 2.4m with drop from 10mm to 40mm on short edge.
I was thinking frame around the edge (to protect the channel for pipes etc) then fill with self levelling compound, but i'm thinking it's going to take about 30 bags.
Could I use a few bags of pre-mix concrete to bring the deeper edge up about 20mm, then levelling compound?
Or what other options?
Thanks for the reply.
That's pretty cheap, but only good to 6mm thickness.
So something like a 4:1 mix across the whole area to bring up to 5-6 mm shy and then self leveller on top ?
Or just fill the deeper bit and then use a leveller that can fill a bit deeper - like 20mm?
(maybe 6-7 bags of https://www.tilevalley.co.uk/index.php?route=product/product&product_id=101)
and will the screed be OK feathering into the slope where it meets ?
I was looking at the screed method, but I don't have access to a mixer, and no way to hire one right now, all i've got is a decent drill and mud mixer attachment, is it viable to mix it up by hand/shovel with one person mixing and one laying ?
You aren't doing that much, so why not get some exercise and knock it up yourself? It'll keep you fit!
