I’ve started installing 14mm click fit engineered wood in my first floor (which has floorboards)
All I did for preparation was screwing down the loose floorboards and replacing the ones in bad shape with 18 mm plywood; I also used a sander to bring down a couple peaks in the floorboards edges (mainly where two joists meet)
I used a 3mm underlay (this one https://www.wickes.co.uk/Arbiton-Ea...Wood-Flooring-Underlay---10-2m2-Pack/p/191372) and started installing the planks parallel to the existing floorboards
After completing the first room I realised the floor squeaks when stepped over, and in some cases it even moves by 3 mm (measured using a 60cm spirit level and puttin my weight next to it)
The subfloor is clearly not levelled and maybe I haven’t used the correct underlay
I am thinking of taking the planks up (I should only break the 6 that I’ve had to glue, but save the rest) and do whatever is necessary to stop the floor from moving and make noise
I am thinking of using a planer wherever there is a step between two adjacent floorboards and then nail down some 3mm hardboard (2.5£/m2) and maybe use a different (thicker? Fibreboard?) underlay
What do you suggest?
