Hello all,
This is my first post, so please be gentle.
I've gone through a number of searches and found various answers to my issue, I'd just like to narrow them down slightly.
Having recently moved into our first property together, my girlfriend and I have started decorating each room to our taste. The property is a bungalow, built in the early 80's by someone who clearly didn't have a plumb line or spirit level! This does nothing for my OCD.
We have completed one guest room to a satisfactory standard. This included removing and relocating a leaking radiator, replacing the damaged floor boards, decorating the entire room, fitting a carpet and furnishing. All done by ourselves, apart from the carpet fitting.
Anyhow, to the issue in hand:
Having removed the carpet and underlay in the second guest room/study, we have noticed there is evidence of damp on the floor boards and more importantly, the floor boards aren't straight.
I'd like to tackle the issue of replacing the damp floorboards and levelling the floor.
Here are some pictures:
You can see the damp patch in the corner of the room, below the studded walls adjoining the hallway and ensuite. I know the damp is coming from a leaking shower cubicle. This will be fixed promptly.
How should I go about replacing the floorboards? Should I cut out and refit or would it be best practice to remove the studded walls and replace the entire floorboards (as I suspect the damage will go into the ensuite and possibly the hall)?
With regards to the un-level floor, could it be poor initial construction or possibly movement? The floor does continue to be un-level into the adjoining ensuite, so this would need addressing as well.
Thank you for taking the time to read through, if I'm required to elaborate any further, please feel free to ask.
Regards,
Ben
Regards,
Ben
