Levelling multiple floors
28 Mar 2011
London
I'm looking at renovating a Victorian house and the floors have some rather large dips (probably due to the usual undersized joists). I haven't been able to check yet whether the joists are sitting fine in the walls but will do so. In terms of levelling each floor out (the dips range from 3 on the top floor in the loft, up to 9cm on the ground floor) I just wanted to check whether the below makes sense.
Jack up ground floor joists 1/8 inch each day using a bottle jack using a large beam perpendicular to the joists until totally level.
Add sister joists with M12 bolts and square plates or joyner bolts.
Add noggins / bracing- is this overkill?
Remove ceiling from floor above, repeat above steps.
Add again for the top floor (existing loft conversion - date unknown).
Any other suggestions / thoughts.
Thanks in advance.
You're wasting your time trying to straighten the old joists. Just sister with deeper ones that will span the (deflected) depth of the existing. On the ground floor I would have thought 90mm is a bit much for simple deflection but if that's all it is I would just replace all the joists as they can't be much use for anything.
