not sure if this goes under plastering or building...
Have removed rotten ancient plasterboard from stud wall posts/battens that used to surround bath. Have moisture resistant gyproc plasterboard to replace it. All the replaced area will be tiled so want to avoid skimming the board. However need to level the boards slightly so that new bath has more snug fit to the wall.
wondering whats best and least painful and least expensive method
1) can I use drywall adhesive between battens and plasterboard to level then screw in place through to the battens
2) use wood shims (a long process)
3) or does it need to be skimmed over after all??
any other ideas/experience welcome
thanks
thanks
