Levelling soil for sub-base
27 Jun 2023
Hi all,
Quick question. I'm building a gravel drive out front. I'm in the process of skimming the topsoil away until I reach a decent firm base.
I'll be honest, it's hard work... I've got enough material away for 150-200mm sub base with 50mm depth gravel on top...
The "levelled" layer has some mild undulations that I just can't be bothered to dig out. At the peak they're low enough to take the full depth of sub base. Cost aside, can I just lay the membrane on this slightly wobbly surface, then rely on a good few layers of wackered mot1 to even it out fully?
So long as the sub base is level I can't see it being an issue, as long as it is deep enough itself?
Cheers
It doesn't have to be perfectly flat, but if excessive there is a risk of variations in the settlement.
Blup
Perfect, thanks for the reply.
Looks like rain has put a halt to anything for a while now though... missus is gonna kill me with the mud getting tracked around... :sneaky:
Do you need the membrane? Wouldn’t it get ruined when you whacker the hardcore? Or is it one of those geotextile things?
Would be geotextile yeah. Need to redo the haunching around the block paving so hoping to get it right up to the edges, never going to 100% dodge the weeds but I'll give it a good go haha.
