Hi all.
Our beloved LG F1247TD Direct Drive washing machine has stopped powering up. What I have tried to date:
Replace fuse.
Try in different socket.
Try other appliances in the washing machine's socket to prove socket ok.
Clean out water filter at front (couple of small coins and some bits of plastic)
Then went on youtube - a few places suggesting you reset the PCB by unplugging, holding down the power button for five seconds then the start button for 5 seconds then powering up. No joy. Still dead to the world.
I then took the display PCB off as the power button 'felt' different to the others. I noted that the power switch on the display PCB was indeed different to the others. I tried a replacement display PCB. Again no effect.
Disconnected the white 'inlet plug where the cord from the mains comes in - reconnected. Disconnected the red one on the same circuit and reconnected. No effect.
Removed, cleaned and reconnected all other electric connectors visible at the top of the machine.
I cant even see a 'Main PCB' let alone get near it to look. Is this a 'remove the back' job on an LG Direct Drive?
Any advice/ support greatly appreciated.
Replace fuse.
