OK clearly not motor that is good but could still be the de-frost as you it would seem have stopped some functions working. It is common practice for home brewers to use old fridge freezers and they will use
a device like this which allows them to have a temperature set out of the normal range of the fridge or freezer.
However the problem is they can only control fridge or freezer not both. With my old Hoover fridge/freezer it controlled freezer temperature and the fridge used a percentage of the cooling and this was common. However with my Samsung there are individual solenoids for fridge and freezer and I have the option of controlling each compartment individually. So with the old Hoover I could use one of those controllers but with the Samsung I could not.
So your options are:-
1) Google for spares and take a chance you have selected the right part.
2) Fit an external controller remember it will then no longer be frost free.
3) Sell it to some one who wants a home brew fridge.
4) Pay for a fridge man to repair it.
The most likely scenario is you have stopped the controller working so the auto de-frost has been stopped and it is the auto defrost element which has failed. When I looked these were £51 and when I tried to get some one to repair my mothers freezer £75 was minimum labour charge so I would expect a bill of around £126 to get it fixed. Clearly only guess work but knowing likely bill does help is deciding the course.
If you were to go deeper and disconnect the defrost element you could prove or disprove if it is the element. The reason I say de-frost element is the mineral insulation is hygroscopic that is it will draw in water if there is the slightest damage to the seals on the end. The jolt the unit got could have damaged the seals and allowed water to get in. I am assuming when you say trips power it is the RCD tripping. Although dust and damp could cause other bits to fail it is less likely.
PS when my mothers freezer thermostat failed I used my home brew controller to run her freezer until the correct parts arrived. However I did have to set a delay and a larger differential than normally used. The problem with the device it does not come in a ready to use form. You need to fit it in to a box and wire up. The other problem is the sensor wire. You need to fit the sensor with mothers freezer it was just put in with the food I only wanted it while waiting for correct parts to arrive.
