I've got an LG Sensor Dry 8kg RC8015C tumble dryer which has stopped draining the water into the tray.
I suspect that either the drain pump is knackered or the pipe leading from the pump is blocked but I can't work out how to access it.
I think this is the part I need if the pump is knackered:
https://www.amazon.co.uk/LG-Tumble-Dryer-Drain-KPS25-325/dp/B00LX3KAB2
I've taken off the sides and I can see it - it's right in the middle underneath the drum.
I must be missing something as these are normally easy to access.
Does anyone know how to get to this pump without dismantling the entire appliance?
Thanks for your help.
