Our LG tumble dryer has given great service for three and a half years. This afternoon we needed to go out and the tumbler was busy, so I turned it off at the stop switch on the front and we went out. On return I pressed the power button, reset the programme and switched it on. About five minutes after it started rotating, the main RCD on the consumer unit tripped. I reset both RCD and machine twice and on each occasion it ran for a few minutes then tripped the RCD again. Having turned various other things on and off and narrowed down the problem to the tumbler and wiring, I disconnected the appliance cable from the fixed wiring point in the wall behind the appliance and connected it to a 13 amp plug to eliminate a fault in the fixed wiring. I plugged it in, turned on the machine and the RCD blew again, so the fault has to be with the machine itself.
Anyone any ideas? First time we've had any problems with this machine.
