Liability when reusing foundations
4 Feb 2014
Bristol
BC have approved re-use of our existing conservatory foundations to rebuild a new single storey extension.
How should we approach liability if the foundations were to fracture or there was some other structural issue with the extension?
Many thanks.
Many thanks.
Contact your home insurance.
You have more chance of winning the Euro this or any week.
You mean you think there is unlikely to be a problem with the foundation… or that it’s unlikely that anyone will want to take responsibility? :cautious:
Many thanks.
I suggest you assess risk rather than liability.
Are there any hedges or trees near the foundation? - ie within 15 metres. Leylandii, hawthorn, oak, willow are species of concern.
What is the ground like - not the top soil, but the ground at foundation depth - shrinkable clay is a concern, hard sand, hard clay, bed rock, mud stone - is generally stable.
Is the area virgin ground or back filled in any way
A stable foundation needs load bearing ground which is not subject to movement caused by water or trees sucking moisture out.
You don’t need much concrete foundation for stability - what is needed is stable hard ground below.
thanks. Yes that is exactly what I am thinking. The footings and slab have been there for 20+ years with no apparent issues, so (as a total layman) I would say the risk is low.
The weigh of a single storey extension (flat roof, glass windows) versus a conservatory (glass roof, cavity breezeblock wall), isn’t going to make a huge difference I’d have thought…
I think my contract with the builder will have to absolve them of responsibility in some way, but I am not sure how to approach that.
Foundations don't fracture.
Whats the difference between building control approving existing foundations, and building control approving new foundations?
Yes My thoughts were that BC approval is approval, job done, but the builder who is quoting for the job raised the issue. I can see his point. He didn’t put the foundations in the ground so he can’t be responsible for any issues. Same goes for getting an SE report I suppose. They won’t be able to calculate an accurate number as they don’t know what went into the ground?
The foundations are mine, so the responsibility has to be mine. I guess I will wait and see whether the builder’s comments actually end up being anything other than comments, but my question here was for advice on how to proceed, perhaps structurally, perhaps legally (contract with builder).
The builder is a bit of a numpty for raising it.
Has this builder ever done a loft conversion, a first story extension, put a beam in retrospectively?
