I have a 3 way mid position value, Lifestyle 679H340-30L0, it looks to be the old model which doesn't have the black button you can press to remove. On the side of the unit there are markings W M H and below there is a slider which you can move when the unit doesn't have power.
What happens is:
power off = slider moves to W due to the spring.
power on = slider stays put until you select either water or heating on the programmer
select heating = slider moves to H and stays put.
select water whilst heating is on = slider moves to M and stays put.
select water without heating on = slider starts to move gets to M and then starts clicking.
If I feel the pipes which go to the radiators and to the hot water tank I can feel each of them getting hot, but I am unable tell if the valve is working for hot water only as the slider will not move to the W position.
I have already replaced the motor and this didn't solve the problem, so does anyone have any ideas, before I need to replace the entire thing!
Matt
What happens is:
Matt
