I need to lift most of the t&g boards in the bathroom.
What's the best way to lift the boards if the joints are glued?
Cut down the joints with a circ saw or multitool where access is tight? Then try to lever up with a crow bar?
Also the joints seem to go under the walls so ill have to cut the boards where they go under the walls.
When it comes to replacing can i just fit noggins to support the ends of the cut boards?
