I have MS and use a wheelchair full-time.
I am looking for something to help me lift objects that are not very heavy, the frame of my lightweight wheelchair, which is under 10kg, and the front end of a trike, I don't know the weight of it, but it has an electric battery and motor so is heavier than 10kg.
Neither one needs to be lifted very high, I want to lift the trike's front wheel into a bike trainer, so about 15 inches or 35cm. The wheelchair frame I want to lift into a scooter basket that is quite high sided, so about a metre total.
I have the upper body strength to lift these objects but when I do so it sets off painful and unpleasant symptoms.
I have looked online at portable floor hoists. They look very similar to patient hoists, and would probably do the job, but are designed to be used from standing and are overkill since they are designed to up to 1, 2 or 3 tons.
I've looked at car boot hoists for scooters, but they are all designed to be fitted in the cars boot. I can't find a portable one.
All of the above options are pretty expensive.
I was hoping there would be a small, easily movable (on castors), not too expensive machine I could use. Does anyone have any suggestions
