Lifting patio slabs?
3 Dec 2004
Hello all,
I've got some uneven patio slabs in my back garden and assume I just need to put some sand underneath to even them out but I can't lift the slabs!
They're in the middle - is there anyway to lift them without lifting a whole row from one end of the patio?
Any ideas greatfully appreciated.
Simon
Use the thin end of a crow bar or a large screwdriver and have another flat blade or a mattock handy. Prise it up with them and they will probably move the other ones slightly to open the gap, once its up enough get another blade under it and lift away. If your going to rebed them, remove whats there and make sure you use sharp snad, not building sand
Cheers Thermo - I did try that this afternoon with a large metal chisel type device I found in the toolbox but couldn't get enough 'wedge' without damaging the slab next to it.
I've had to lift some other slabs from the other end of the patio so have got plenty of sand!!!
I have been doing this job today, and used a spade to lift the slabs. No problems at all.
Incidentally, they were bedded on coal slack. Very popular and effective in the days when we all used coal. :D
A garden fork can be used if the gaps are big enough.
Should you put a layer of hardcore/gravel/stones under the sand?
if its only for foot traffic then a compacted bed of sharp sand is fine.
