Light Bulb Blowing Problem
2 May 2007
Hi All
I have installed a remote control dimmer switch in a room and for some reason (not too sure if this has happened from install) whenever the light is ON in the room and someone switches off the bathroom light, the bulb blows in the room with the remote control dimmer.
Any ideas as to what this is? I am going to change out the dimmer to a normal type dimmer switch and see what happens, just a little concerned as to why the bulb blows (it doesnt switch the fuse though, just the bulb). Its happened about 5 times now.
Help
Lee
Yes i believe so, when i flick the fuse both bathroom and bedroom lights go off.
Bathroom lights are powered through a transformer in the void.
Originally i put on the remote control dimmer which was blowing bulbs (not all the time but much more than normally).
This weekend i swapped out this dimmer switch for a normal twist dimmer. No bulbs blown yet but switch itself buzzes and bulb flickers quite a lot.
Swapped this out for a normal ON/OFF switch and problem solved.
Really would like to put the originally dimmer back in though, any ideas what was causing the bulbs to blow?
Lee
Are the dimmer and its load (the lamp and any control gear) compatible with eah other?
